4 Pages123>»
Gator
#1 Posted : Monday, November 5, 2007 10:29:58 AM(UTC)
Gator
After filling soap into dispenser ... sliding plastic door won't stay shut. Is it a worn out door or does the entire dispenser assembly need to be replaced?
Thanks,
Bud
#2 Posted : Monday, November 5, 2007 10:58:06 AM(UTC)
Hi Gator
In most cases the problem is just a detergent cup latch. It needs more careful visual inspection because it could be the complete dispenser damaged.
- The part number for the detergent cup latch AP2802332
- The part number fro the dispenser assembly AP3844311
- Here are the break down diagrams for the Bosch dishwasher Model SHU4306 UC/12 (FD 8003-)
Good luck.
Johntl
#3 Posted : Wednesday, March 11, 2009 12:27:57 PM(UTC)
Johntl
Hi Gator
Good luck.
Hi Gene,
I was wondering if you could help me. I have a Bosch SHY66C05UC dishwasher and the soap dispenser doesn't open to let out the soap anymore. I tried just adding the soap at the beginning of the cycle but the dishes come out terribly dirty and greasy. The door slides easily enough when I push on it and the little release lever works fine too. Do you have a diagram and /or instructions on how I could fix this myself? Also, where can I order parts from?
Thanks in advance,
John
#4 Posted : Wednesday, March 11, 2009 3:19:15 PM(UTC)
John,
What are the two numbers after back-slash in the model number?
Johntl
#5 Posted : Wednesday, March 11, 2009 3:23:28 PM(UTC)
Johntl
John,
Gene,
The two numbers are 23.
Thanks,
John
Johntl
#6 Posted : Monday, March 16, 2009 4:22:24 AM(UTC)
Johntl
Hi Gene,
Are you still there? I haven't heard back from you yet.
John
#7 Posted : Monday, March 16, 2009 4:33:34 PM(UTC)
John,
Sorry for the delay. Unfortunately I'm not able to find the parts list for this model. The closest I found has 14 at the end of the model number and I'm not sure if the part numbers are the same.
Johntl
#8 Posted : Wednesday, March 18, 2009 2:26:22 PM(UTC)
Johntl
Gene,
Thank you for looking. A few other questions for you: Would the part on my dishwasher have any markings on it that indicate what the part number is? What part is it anyway that you believe is bad? Do you have a diagram that could help me get to and remove the defective part? Can I take the defective part in to a local (Chicago) appliance parts store and ask them to get me a replacement for it?
Thanks again,
John
#9 Posted : Wednesday, March 18, 2009 4:53:13 PM(UTC)
Originally Posted by: Johntl Go to Quoted Post
...1. Would the part on my dishwasher have any markings on it that indicate what the part number is?...
...2. What part is it anyway that you believe is bad?...
...3. Do you have a diagram that could help me get to and remove the defective part?...
...4. Can I take the defective part in to a local (Chicago) appliance parts store and ask them to get me a replacement for it?...
John,
1. I do not think so.
2. Most likely the problem is a bad soap dispenser.
3 & 4. You have to remove the outer door panel to access the part. I do not have the diagram, but you can live chat with the Appliance Parts Pros team and they will help you to find the diagram and the right part with the best price.
Johntl
#10 Posted : Wednesday, March 18, 2009 5:28:15 PM(UTC)
Johntl
Thank you again Gene.
-John
Bosch soap dispenser problem (Dishwasher Repair)
by mtds 1/21/2013 6:36:43 AM(UTC)
4 Pages123>»
