Grady White
#1 Posted : Sunday, September 16, 2012 8:20:11 AM(UTC)
Grady White
I can't seem to figure out how to open or remove the control panel. Any help would be appreciated.
sidfink43
#2 Posted : Tuesday, September 18, 2012 4:24:28 PM(UTC)
sidfink43
On this model you can pry off the end caps. This will expose screws on each side of the front of the console at the bottom of it. Take them out and the console will flip up.
Yep, that should do it.
Grady White
#3 Posted : Tuesday, September 18, 2012 6:11:11 PM(UTC)
Grady White
I tried to remove the end caps but they didn't want to come off. Where does one need to pry?
sidfink43
#4 Posted : Wednesday, September 19, 2012 7:40:39 AM(UTC)
sidfink43
Pull from the top, if you want to use a screw driver you can just be careful.
If you break one don't worry, they are easily replaceable, or can even be left off without affecting the operations of the machine.
Grady White
#5 Posted : Thursday, September 20, 2012 5:10:55 PM(UTC)
Grady White
Thanks much. I'll give it a try.
Removing control panel and installing new control board (Oven Repair (including Ranges and Cooktops))
by devronh 3/4/2014 6:27:03 AM(UTC)
Removing Control Panel Wall Oven (Oven Repair (including Ranges and Cooktops))
by Germanyjon 4/30/2013 6:45:26 AM(UTC)
Need help removing control panel and front panel to get at the drain pump (Washer Repair)
by jthenne 2/16/2011 11:43:38 AM(UTC)
Removing control panel (Washer Repair)
by cbelt 1/4/2011 5:00:58 PM(UTC)
Removing control panel (Oven Repair (including Ranges and Cooktops))
Belarus mamacitizen 3/7/2010 3:58:18 PM(UTC)
Need guidance on removing control panel (Oven Repair (including Ranges and Cooktops))
by NCAmy 10/30/2009 1:59:29 PM(UTC)
