jdrepair
#1 Posted : Saturday, September 15, 2012 3:16:03 PM(UTC)
jdrepair
Refrigerator and freezer warm. I believe its a leak, but would like to verify. Model Frigidaire frs26r2aw4. No frost is present on evap coils. I have tested the compressor via ohm meter and it checked out. Capacitor checked out. Compressor runs but lines are room temp. The point where copper turns to aluminum at evap coil is cool to the touch. All fans run. Have checked the door switches and control dials and all checked out. Overload relay does have a slight rattle to it. The fridge set for 2 years and upon cleaning and plugging up to use I discovered a broken water valve due to freezing and thawing as it had set in an empty, unheated house.
Anybody have other ideas? I really need to get this fridge going. Thanks.
#2 Posted : Tuesday, September 18, 2012 3:20:14 AM(UTC)
Replacement parts for Frigidaire FRS26R2AW4 Frigidaire/refrigerator | AppliancePartsPros.com
I am assuming that the compressor runs continuously and that you can feel it vibrating.
If yes then you have a sealed system problem. This will be an expensive repair as you need a pro. In many cases it makes more sense to put those dollars towards a new unit.
Amana ABB2224WEB2 freezer and fridge warm (Refrigerator & Freezer Repair)
by aefbae 12/30/2020 10:38:33 AM(UTC)
Whirlpool Defrost not working and freezer and fridge warming up (Refrigerator & Freezer Repair)
by kimberdesi 9/13/2017 12:37:45 PM(UTC)
Maytag WFF2557HEB French Door, Freezer and Fridge Warm (Refrigerator & Freezer Repair)
by Agent0071 10/18/2016 7:13:59 AM(UTC)
Freezer and fridge warm (Refrigerator & Freezer Repair)
by Ukchris 6/29/2012 10:27:34 AM(UTC)
Freezer and fridge warm. (Refrigerator & Freezer Repair)
by audley 10/4/2011 12:15:02 PM(UTC)
by dr67 2/18/2010 5:48:59 PM(UTC)
