monickm
#1 Posted : Monday, April 6, 2009 9:50:10 AM(UTC)
monickm
Hi, my washer doesn't spin or drain, I don't know what to. I checked the outlet for power, it is ok because it goes on the washing cycle, the lid seems to be ok, so my guess is that it may be the pump or something else, can you help?:confused:
Thank you!
#2 Posted : Tuesday, April 7, 2009 2:11:13 PM(UTC)
The first and major failure suspect is the lid switch (#11 on the diagram). It is easy to test it. Open the control panel, unplug the lid switch wire plug and bypass it. Run the washer. If it does drain and spin then the lid switch has to be replaced.
- The part number for the lid switch is AP3100003
Here are the break down diagrams and Replacement parts for WHIRLPOOL KAWS577EQ0 | AppliancePartsPros.com
