mgatto
#1 Posted : Monday, March 31, 2008 8:50:38 AM(UTC)
mgatto
Rank:: Member
Hello, I would like to learn how to replace the lower interlock switch on my microwave...the light and the timer work, the turntable does not turn and it does not heat. It happened before...is it easy to replace? Thanks.
Mia
kenriordan
#2 Posted : Monday, April 6, 2009 9:19:05 AM(UTC)
kenriordan
Mia
WE HAVE A GE ze1660sa003 MICRWAVE. iT WON'T HEAT UP UNLESS YOU PRESS THE BUTTON PARTWAY IN. i DON'T KNOW IF IT IS THE BUTTON, THE DOOR SWITCH OR THE SWITCH MONITOR OR THE LATCH BODY. cAN YOU HELP ME FIGURE IT OUT?
tHANK yOU
#3 Posted : Tuesday, April 7, 2009 1:35:00 PM(UTC)
Mia
Mia,
Remove the top grille and open the control panel. All switches are screwed to the latch board (#28 on the diagram).
- The part number for the interlock switch is AP2024367
#4 Posted : Tuesday, April 7, 2009 1:40:33 PM(UTC)
tHANK yOU
Most likely the problem is a bad interlock switch (#26 on the diagram), probably the upper one. This switch is very likely melted and wires to it are scorched.
- The part number for the interlock switch is AP2024337
