2 Pages<12
#11 Posted : Thursday, September 13, 2012 1:58:48 PM(UTC)
Originally Posted by: eugermach Go to Quoted Post
Gene:
I got the part, but I am not sure how this escutcheon or trim plate is removed. I do not want to break it, and am not positive on how to remove. Any help to get it off will be appreciated. Some forums discuss pushing and removing by the tabs. Not sure how it works.
The instructions are attached to the reply. There is nothing too difficult.
File Attachment(s):
How to open ice dispenser.doc (97kb) downloaded 13 time(s).
eugermach
#12 Posted : Thursday, September 13, 2012 4:58:49 PM(UTC)
eugermach
Tried that, but it only got me to the chute flapper section. It doesn't appear that section can be removed to get to the hose (which appears to be screwed in behind the section. I looked in the tech manual that you got this from, and it appears to indicate that I would have to remove the door panel and insulation and gasket to get to the screws for removal. Not sure, but unless you have another method, I will be trying that next.
#13 Posted : Friday, September 14, 2012 3:13:22 PM(UTC)
...I would have to remove the door panel and insulation and gasket to get to the screws for removal...
Looks like that this is the only way to do it.
2 Pages<12
