Hello I have a Samsang RF265AABP/XAA French Style Fridge that has no displays and is dead. I measured the voltage from the Power Supply Board and I get my 12 Volts and 5 Volts DC. So that looks good. However when I measure both voltages coming into the Main Control Board at the connector the voltage pulses. Fluctuates. This is at the Main Board connector. I suspect the Main Board is bad. Any help? My email is Ladyt1@Email.Com. Any help is appreciated. Cary:)
