roperstopper
#1 Posted : Friday, September 7, 2012 7:07:09 AM(UTC)
roperstopper
I have a roper/whirlpool 4 cycle washer.It works great through all wash cycles,fills-aggitates,drains and spins,but will not start the rinse cycle on any of the wash options.Does not begin to fill,etc. Timer is silent-no noise-no nada.
thanks
Simon / APP Team
#2 Posted : Friday, September 7, 2012 8:18:54 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely the rinse cycle is set for cold water only. Check if you are getting cold water to the washer, then check the water valve. If it's getting 120VAC to the solenoid - replace it Part number: 285805
roperstopper
#3 Posted : Saturday, September 8, 2012 11:59:01 AM(UTC)
roperstopper
Thanks I'll Check Into It
ancel1961
#4 Posted : Sunday, September 9, 2012 12:05:27 PM(UTC)
ancel1961
Thanks Simon / APP Team,
You gave me the solution to the problem I was having with my washer
You took a load off my shoulders
Take care ;)
Simon / APP Team
#5 Posted : Monday, September 10, 2012 8:54:55 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
