catman42
#1 Posted : Tuesday, September 4, 2012 8:56:31 AM(UTC)
catman42
I ordered a seal for the freezer door using p/n 2159327 , I recieved the new part looks ok.
The original one is not fastened with screws but looks like it is built into the door. The new one has a tab built into the upper inside rear . I can not figure out how to replace this.
please help
Simon / APP Team
#2 Posted : Tuesday, September 4, 2012 2:55:25 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Looks like the gasket is a "push in" type.Is the original one black or white?
The instructions sheet should be in the package.
Simon.
catman42
#3 Posted : Wednesday, September 5, 2012 4:15:40 AM(UTC)
catman42
thanks for the reply
the original seal is white or beige. I did not get any instructions with it. If there are any I would appreciate a copy. Do I just pull the old one out of the door??
thanks again
catman42
#4 Posted : Wednesday, September 5, 2012 4:55:26 AM(UTC)
catman42
thanks Simon
the original is white, I did not get any instructions with the new one.
If there any available I would appreciate a copy..
thanks again
Simon / APP Team
#5 Posted : Wednesday, September 5, 2012 12:10:01 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Carefully pull out small portion of the old gasket and see if there is the groove. If it's there just push the new one in.
Simon.
catman42
#6 Posted : Wednesday, September 5, 2012 2:26:13 PM(UTC)
catman42
thanks Simon
I will give that a try??
Guest (5)
