BuffaloChickenWing
#1 Posted : Monday, September 3, 2012 5:10:34 PM(UTC)
BuffaloChickenWing
Hello. About 6 months ago my dishwasher wouldn't clean the top rack of dishes..I figured out that there was no water coming out of the top sprayer, The Chopper Assembly was clogged up.. I pulled it out and cleaned it up, Problem solved...But, every 2 months It does the same same thing even though we try the scrap off the plates before we put them in now but it still clogs up every few months.. My question is, Why did it work fine for over 5yrs, and now it clogs up in a few months?
UserPostedImage
UserPostedImage
installed after I cleaned it up,
UserPostedImage
UserPostedImage
Thanks for any help
#2 Posted : Tuesday, September 4, 2012 2:46:15 PM(UTC)
Very likely the problem is a worn out teeth on the pump impeller and/or chopper. You can try to replace the impeller. In that case you should replace the "O" rings to prevent possible water leak. Whirlpool does not sell them separate so you have to order the volute too. I personally would replace the whole pump & motor assembly to avoid the headache of getting it all together to find out a water leak and noisy motor (very common issue). It's worth to spend more money for much more reliable repair.
- The impeller kit Part number: 8193951
Cafe fridge keeps warming up. Help! (Refrigerator & Freezer Repair)
by Guest 6/28/2024 8:33:23 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Nursing Paper Review SOS: Help a Peer Out! (General Talk)
by Guest 6/19/2024 3:00:02 AM(UTC)
Diagnostic Code Help (I screwed something up) (Refrigerator & Freezer Repair)
by megarms 5/20/2024 7:30:54 AM(UTC)
Freezer Help from Whirlpool Unit (Refrigerator & Freezer Repair)
by Guest 5/15/2024 5:37:40 AM(UTC)
Door Switch Help With Samsung Microwave Model ME21M706BAS (Microwave Repair)
by clagrow 5/2/2024 6:28:45 AM(UTC)
Need Help Identifying Part Manufacturer (Oven Repair (including Ranges and Cooktops))
by anonymous24 5/1/2024 3:25:51 PM(UTC)
Help! Washing machine on repeat rinse cycle (Washer Repair)
by cali.poppy 4/29/2024 9:08:28 AM(UTC)
Cant remove Samsung ice bin , need help please (Refrigerator & Freezer Repair)
by Orlando123 4/20/2024 10:55:35 AM(UTC)
help maytag comercial dryer (Dryer Repair)
by blackwell316 4/4/2024 5:05:48 PM(UTC)
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal (Washer Repair)
by gocanada72 3/18/2024 5:53:29 AM(UTC)
GE Frontload Washer - Trouble Shooting Help (Washer Repair)
by mahgnibb 3/14/2024 2:37:10 PM(UTC)
Help finding the right screws to secure the top panel. (Washer Repair)
by mikkel3906z 2/20/2024 12:30:41 AM(UTC)
Dishwasher electrical help (Dishwasher Repair)
by Guest 1/11/2024 4:35:37 PM(UTC)
Washer help please maytag (Washer Repair)
by Guest 12/13/2023 4:45:08 AM(UTC)
