italianmeatball77
#1 Posted : Tuesday, December 4, 2007 3:24:39 PM(UTC)
italianmeatball77
I have a 3 year old Kenmore gas range/oven. The oven light is supposed to turn on when the oven door is open, and turn off when it is closed. It also has a switch on the control panel. However, the light is stuck on and never turns off, even when I hit the switch. Any ideas?
#2 Posted : Wednesday, December 5, 2007 12:15:52 PM(UTC)
The first thing I would check is the door switch (#12 on the break down diagram).
If there is nothing wrong then the problem is a bad control board.
- The part number for the door switch AP3851660
- The part number for the control board AP3882295
