rosnik
#1 Posted : Sunday, April 5, 2009 2:17:13 PM(UTC)
rosnik
Both the fridge portion and the freezer are cold at the bottom levels but warm at the top. What could be the problem? What should I look at in order to fix the problem? Please help....Thanks in advance
Drags1998
#2 Posted : Sunday, April 5, 2009 4:19:58 PM(UTC)
Drags1998
Is the freezer fan running? Do you see ANY frost on the inside rear wall of the freezer? is the air duct in the bottom of the food compt. clear into the freezer?:)
rosnik
#3 Posted : Monday, April 6, 2009 11:34:34 AM(UTC)
rosnik
The freezer fans is running. I do see build up of frost on the back of the freezer. I am not sure how to tell if the food comp. vent is clear.
Drags1998
#4 Posted : Monday, April 6, 2009 11:37:48 AM(UTC)
Drags1998
If you see frost, THATS your problem!!!! :)
woodchuckie
#5 Posted : Monday, April 6, 2009 11:48:15 AM(UTC)
woodchuckie
Check your defrost heater, defrost thermostat.
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
If they are ok it's your motherboard. Part 801 on your motherboard diagram. Replacement parts for GE ESH25XGPABB | AppliancePartsPros.com
rosnik
#6 Posted : Monday, April 6, 2009 1:31:51 PM(UTC)
rosnik
where do I check the defrost heater and defrost thermostat. Should I replace them, and if so, can I do it or do I need to call a repair man.
rosnik
#7 Posted : Monday, April 6, 2009 1:33:10 PM(UTC)
rosnik
Should I just break down and buy a new fridge. I need suggestions people...lol...Help because I can only fit so much food on the bottom half of the unit..lol
woodchuckie
#8 Posted : Monday, April 6, 2009 2:02:07 PM(UTC)
woodchuckie
click on the line below. Refrigerator repair guide.
