Storm75
#1 Posted : Thursday, August 23, 2012 7:02:50 AM(UTC)
Storm75
AMANA FRIDGE ARS2464BW
I replaced the icemaker assembly with your part # AP4135008 (D7824706Q) as it was leaking from the bottom. That went well and the unit functioned for about a week or so. Now it won't make ice at all, or very little. Can you point me in the direction as to what to test next, perhaps a fill-valve is on the blink? Note that the water dispenser on the door works fine - just no ice. And the auger turns OK etc. Thank you!
Simon / APP Team
#2 Posted : Thursday, August 23, 2012 10:59:49 AM(UTC)
Simon / APP Team
Groups: APP Team
HI.
Check if the temperature in the freezer is about 0*F.
Then switch around the electrical plugs at the water inlet valves (one valve at the time).
Push the water dispenser lever. If the icemaker fills up - it's bad. If not - replace the corresponding water valve.
Here are the breakdown diagrams and Cabinet back replacement parts for Amana ARS2464BW REF - SXS/I&W | AppliancePartsPros.com
Post the results.
Simon.
Storm75
#3 Posted : Thursday, August 23, 2012 11:27:17 AM(UTC)
Storm75
Thank you - I will check and advise!
Simon / APP Team
#4 Posted : Thursday, August 23, 2012 1:32:19 PM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
Storm75
#5 Posted : Thursday, August 30, 2012 5:12:15 AM(UTC)
Storm75
Originally Posted by: Simon / APP Team Go to Quoted Post
You are welcome.
Simon.
Update: for now it looks like the issue is resolved - thank you!
A combination of buying/using a freezer thermometer and cleaning the coils in the bottom of the unit brought the icemaker back to life - thanks again! :)
Simon / APP Team
#6 Posted : Thursday, August 30, 2012 9:41:01 AM(UTC)
Simon / APP Team
Groups: APP Team
You are very welcome.
Simon.
