Groups ready for retrieval: Registered
The oven shuts off usually within the first ten mins. Repeat turning on oven and have varied temp range settings. The oven will eventually stay on but will take many attempts
Groups: APP Team
Hi.
When you say oven shuts off does the control board still shows Bake and temperature? Does the display stay on?
Thank you.
Simon.
Temp. And bake displays are gone but clock and timer continue to work
Groups: APP Team
Thanks Simon for your response, but I have some concerns about the control board. Do you think the heat from door is the cause, and is this going to be an issue every two years?
Groups: APP Team
Hi.
Unfortunately the Maytag doesn't give us any recommendations on this issue.
Simon.
