TMeck
#1 Posted : Wednesday, August 22, 2012 2:00:23 PM(UTC)
TMeck
The oven shuts off usually within the first ten mins. Repeat turning on oven and have varied temp range settings. The oven will eventually stay on but will take many attempts
Simon / APP Team
#2 Posted : Wednesday, August 22, 2012 4:02:14 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
When you say oven shuts off does the control board still shows Bake and temperature?
Does the display stay on?
Thank you.
Simon.
TMeck
#3 Posted : Wednesday, August 22, 2012 4:13:09 PM(UTC)
TMeck
Temp. And bake displays are gone but clock and timer continue to work
Simon / APP Team
#4 Posted : Friday, August 24, 2012 10:08:51 AM(UTC)
Simon / APP Team
Groups: APP Team
HI.
Most likely it's the control board Part number: 8507P229-60
Here are the breakdown diagrams and Replacement parts for Maytag JGS8860BDP17 30" GAS SLIDE-IN | AppliancePartsPros.com
Post the results.
Simon.
TMeck
#5 Posted : Monday, August 27, 2012 5:49:03 PM(UTC)
TMeck
Thanks Simon for your response, but I have some concerns about the control board. Do you think the heat from door is the cause, and is this going to be an issue every two years?
Simon / APP Team
#6 Posted : Tuesday, August 28, 2012 9:31:44 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Unfortunately the Maytag doesn't give us any recommendations on this issue.
Simon.
