michaelman31
#1 Posted : Sunday, December 2, 2007 4:57:24 AM(UTC)
michaelman31
My magic chef oven model#6498vrv is not maintaing proper temperature. I have replaced the oven sensor. Then checked oven temperature with a thermometer and temperature is off by 200-300 degrees. Last year I replaced the touch panel , which fine. I have searched for other parts that might be the problem, I found Relay board
Part Number: AP379876 made by MAYTAG could this be needed? Any other suggestions or parts would be greatly appreciated. I'm sure there is a thermastat somewhere built into a part, could that relay board be it ?
Thank You Michaelman31
#2 Posted : Sunday, December 2, 2007 9:45:30 PM(UTC)
Most likely the problem with your oven is a bad control board (aka clock).
This is the part which operates with the relay board due the oven sensor readings.
- The part number for the clock AP382949
- Here are the break down diagrams for the Magic Chef range Model 6498VRV
michaelman31
#3 Posted : Tuesday, December 4, 2007 12:55:32 PM(UTC)
michaelman31
Thank you Gene , is the thermastat in the control panel (clock) ? DO you have a wiring schematic? Thanks again for your help Michaelman
#4 Posted : Tuesday, December 4, 2007 1:44:30 PM(UTC)
Your oven does not have any thermostats, just the control board.
Unfortunately I do not have the wiring diagram for your oven.
michaelman31
#5 Posted : Tuesday, December 4, 2007 3:23:00 PM(UTC)
michaelman31
Thank you Gene.I will order the control panel .
ripleys
#6 Posted : Tuesday, December 4, 2007 6:03:42 PM(UTC)
ripleys
Yes Gene is 100% correct on diagnosing the clock. Maytag (Magic Chef) clocks are known for going eratic in the temperature department.
