my freezer seems to be running normal except that the bottom started to thaw and a large amount of frost build up on the top three inches most of it being on the right side if you were standing in front of it. It is a older one but dont want to buy a new one if i can drop a few dollars in it.
Originally Posted by: Ben W  my freezer seems to be running normal except that the bottom started to thaw and a large amount of frost build up on the top three inches most of it being on the right side if you were standing in front of it. It is a older one but dont want to buy a new one if i can drop a few dollars in it. Please email me at bwancour@yahoo.com
Groups: APP Team
Hi.
Check if the door gasket is tight and there is no air leak.
Simon.
RE: Chest freezer - gasket okay, no leaks, freezer runs like a refrigerator but does not freeze - compressor running but not freezing - is there some type of refrigerate to use? bwancour@yahoo.com
Groups: APP Team
Hi.
Most likely there is the sealed system problem. This is the job for a trained technician.
Simon.
