healerr
#1 Posted : Sunday, August 19, 2012 8:14:22 PM(UTC)
healerr
Here's some history: We noticed the oven will not work when we turn it on. The range top still works and the clock does not work. I plugged a extension cord in one of the outlets and thats when the oven stopped working.
#2 Posted : Tuesday, August 21, 2012 2:33:21 AM(UTC)
I cannot fond any info on the given model number, please check it.
I am assuming that the oven is controlled by the clock and does not have a separate dial/thermostat.
Though you post seems to indicate something different as you mention the oven and the clock as separate items ( oven will not work when we turn it on. The range top still works and the clock does not work)
Does the interior oven light come on when the door is opened.
If not you may have a power problem.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
The clock, oven light etc. usually run off of L1 to Neutral.
If OK
If OK
Be careful as 240 volts is lethal !!!
Oven and clock not working (Oven Repair (including Ranges and Cooktops))
by Kelley966 5/21/2013 7:10:33 PM(UTC)
Oven and Clock not working (Oven Repair (including Ranges and Cooktops))
by Njauregui 6/26/2009 3:56:06 PM(UTC)
ge oven and clock not working (Oven Repair (including Ranges and Cooktops))
by trader 5/18/2009 3:40:09 AM(UTC)
by Flyboy66 12/8/2008 1:11:33 PM(UTC)
by maryc 11/11/2007 2:35:14 PM(UTC)
