2 Pages<12
packersphan
#11 Posted : Saturday, April 4, 2009 12:29:17 PM(UTC)
packersphan
on the main motor, checking the main windings (P3, P4, &P5) these are the Main Winding, Aux. Winding-Wash, and Aux. Winding-Drain. When I check across these connections, I have continuity to each and all of these three connections. Is this how it is supposed to be.
#12 Posted : Saturday, April 4, 2009 5:23:13 PM(UTC)
Yes
They are all connected together at the connection on the right hand side of the motor on the wiring diagram (R-BK). To check each one individually one meter lead must be on the R-BK and then the other lead to P3 or P5 or P4.
As an example of what you are doing if Main winding is 3 ohms and Wash winding is 5 ohms, when you measure P3 (Main) to P4 (Wash) you are measuring those 2 windings in series so you should read 8 ohms.
2 Pages<12
