I have a Kenmore 70 series washer that won't drain. It does spin and agitate fine. I replaced the pump with a new one and checked all hoses for blockage? Any Idea what I can do next?
Perhaps the switch or relay that controls the drain valve is bad or has a bad connection. I'd try to find a schematic and start there.
Originally Posted by: ditosp Perhaps the switch or relay that controls the drain valve is bad or has a bad connection. I'd try to find a schematic and start there. Found Schematic on Sears website no drain control parts that I can find goes straight from drum to pump to drain pipe?:confused:
