kevlarnovack
#1 Posted : Monday, December 3, 2007 5:56:39 PM(UTC)
kevlarnovack
I've had my Kemore dishwasher for about 2 years. Recently the Normal Wash light started blinking about 18 times straight, hesitates momentarily, and continues the blinking cycle again.
I first unplugged the original board & plugged it back in & it worked for a week or so. But, then it started the blinking again. That little trick no longer works.
I replaced the circuit board with a new one. The problem still exists.
I tried another suggestion of toggling HI TEMP WASH/HEATED DRY for 5 minutes. Nothing happened.
I read also the it could be the heating coil or maybe another sensor. I haven't tried any of these as of yet. I wouldn't know where to look. Does anyone have any idea what I need to do to get this working again? I am totally stumped on this.
Thanks!
#2 Posted : Monday, December 3, 2007 9:44:51 PM(UTC)
The LED, flashing rapidly means the control board sensed a stuck key or shorted circuit in key pad.
In order to fix the problem, the console has to be replaced.
- The part number for the black console AP3777661
- The part number for the white console AP3777709
- The part number for the biscuit console AP3777710
kevlarnovack
#3 Posted : Wednesday, December 5, 2007 4:05:40 PM(UTC)
kevlarnovack
Okay, I'll give that a try. Another $120 down the drain. :eek: The part was out of stock on the link you provided. As much as I hate ordering through Sears, I went ahead & did. :rolleyes:
I took apart the keypad to see if maybe some water crossed the contacts. It didn't come apart very neatly, but I was able to wipe some moisture away & get it to start for a moment. It cut back out after awhile. I babysat the thing to get a complete load washed, but this definitely is not the way I want to do my dishes.
Thanks for you assistance, Gene. I'll post back my results from the new part.
kevlarnovack
#4 Posted : Tuesday, December 11, 2007 4:13:50 PM(UTC)
kevlarnovack
Gene,
Thanks again for the assistance. Replacing the panel resolved my issue. I was hoping for a less expensive option, but I can wash dishes once again.
normal wash light blinking (Dishwasher Repair)
by dirtydishes1970 3/11/2009 2:54:28 PM(UTC)
