Lookin for Answers
#1 Posted : Friday, April 3, 2009 7:37:20 PM(UTC)
Lookin for Answers
The issue I am having is the problem of not getting water to pump through the wash arms.The drain pump is ok, and water level is just under the heating element. I have checked the impeller as I have found recomended through out this forum. The impeller is not attached to the pump shaft, motor spins impeller does not, I have pulled the moter and noticed that the impeller shaft appears to have been press fitted over the motor shaft. I looked at the parts list referenced from the parts drawing (GLDB656J) and could not find anything that looked to be an impeller shaft that would run through the drum,blade and rear bracket that would slide over the motor shaft. I reviewed the Frigidaire service manual (linked from here) and found that the pump / impeller assembly is to be replaced as a unit. IS THIS TRUE?(The motor seems fine). If thats the case will there be possibilities of the tub being warped and the unit not fitting back in? Do you think that I'm on the right track or am I all wet? Sorry for the book I wrote. I will appreciate any assistance on this issue. Thank You.
#2 Posted : Saturday, April 4, 2009 2:41:21 PM(UTC)
Originally Posted by: Lookin for Answers Go to Quoted Post
...I reviewed the Frigidaire service manual (linked from here) and found that the pump / impeller assembly is to be replaced as a unit. IS THIS TRUE?...
...will there be possibilities of the tub being warped and the unit not fitting back in?...
...Do you think that I'm on the right track...
Yes, this is true.
Yes, there is a small chance for the tub to be warped and it's very hard to see.
Yes, you are on the right track. If your decision is to fix it then the dishwasher has to be removed from the cabinet.
Here are the break down diagrams and Replacement parts for FRIGIDAIRE GLDB656JT0 | AppliancePartsPros.com
Lookin for Answers
#3 Posted : Sunday, April 5, 2009 8:07:11 AM(UTC)
Lookin for Answers
Yes, this is true.
Gene,
Thanks for answering so quickly, If I am following this correctly I should purchase the assembled unit #70 in the parts diagram because the original design of this dishwasher does not allow for individual parts to be replaced on the wash delivery system.
#4 Posted : Monday, April 6, 2009 2:35:47 PM(UTC)
Yes, you are right. The part number for the motor and pump assembly is AP3160640
Guest (5)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
