allantag
#1 Posted : Thursday, August 2, 2012 12:58:01 PM(UTC)
allantag
My Whirlpool Washing Machine Does Not Spin Down Clothes. What Parts Are Causing This To Happen ?
Simon / APP Team
#2 Posted : Thursday, August 2, 2012 1:55:55 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Does the washer spins at all? Does it drains?
Thank you.
Simon.
allantag
#3 Posted : Thursday, August 2, 2012 2:05:56 PM(UTC)
allantag
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Thank you.
Simon.
THE WASHING MACHINE TUB APPEARED TO WANT TO SPIN, BUT DOES NOT SEEM TO SPIN NOW.
allantag
#4 Posted : Thursday, August 2, 2012 2:08:22 PM(UTC)
allantag
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
allantag
#5 Posted : Thursday, August 2, 2012 2:11:36 PM(UTC)
allantag
Hi.
Thank you.
Simon.
THE MACHINE DOES DRAIN.
Simon / APP Team
#6 Posted : Thursday, August 2, 2012 2:43:10 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If the washer agitates remove the agitator and check if the drive block is not stripped Part number: 389140
Part number: 389140
If the drive block is OK then most likely the problem is the clutch Part number: 285785
Part number: 285785
Here are the breakdown diagrams and Replacement parts for Whirlpool GSW9650LW0 AUTOMATIC WASHER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
whirlpool washing machine model wtw57esvw0 (Washer Repair)
by Guest 5/7/2024 7:57:17 AM(UTC)
Whirlpool Washing Machine won't start/fill (Washer Repair)
by greekguy7 12/8/2023 4:53:34 AM(UTC)
Whirlpool washing machine drive hub (Washer Repair)
by Guest 4/23/2023 7:29:26 AM(UTC)
Whirlpool washing machine not spinning properly (Washer Repair)
by Guest 6/9/2021 9:12:59 PM(UTC)
Whirlpool washing machine destroying water pumps (Washer Repair)
by mjcarb 8/30/2016 11:53:49 AM(UTC)
whirlpool washing machine (Washer Repair)
by gman2233 5/27/2015 6:32:08 PM(UTC)
Whirlpool washing machine drain/spin noise (Washer Repair)
by wlakeberry84 6/24/2014 8:25:04 PM(UTC)
by tungkiu 12/5/2013 3:42:15 PM(UTC)
Whirlpool Washing Machine Plastic Washers (Washer Repair)
by ohcableman 7/4/2013 10:28:31 AM(UTC)
whirlpool washing machine will not spin out everytime (Washer Repair)
by rdgiles1 4/16/2013 6:50:00 AM(UTC)
Whirlpool Washing Machine (Washer Repair)
by Texasdiyer 3/25/2013 5:10:12 AM(UTC)
Whirlpool Washing Machine Agitates for the entire cycle (Washer Repair)
by swkucera 12/4/2012 5:09:02 AM(UTC)
by edie590 8/16/2012 8:29:21 AM(UTC)
by sunshine123 9/3/2011 8:05:34 PM(UTC)
Whirlpool washing machine LSQ9010KQ0 timer replace instrucions (Washer Repair)
by PlankOwner 12/29/2010 8:59:42 PM(UTC)
