I replaced the freezer condensing fan upon recommendation and it still does not work. I do have 120 at the red/white and brown leads coming from the back plug. Ground is connected. I also do not have any water flowing at the door? Unit is empty. What to replace now as I am stumped. I did read other suggestions but since I have 120 at the connection I am perplexed.:confused:
Measure the motor fan voltage with it pluged in.
