Jeff Buck
#1 Posted : Friday, April 3, 2009 4:26:35 PM(UTC)
Jeff Buck
Final rinse trickles in, fills in about 1/2 Hr. Then have to turn selector to get it to spin
Jeff Buck
#2 Posted : Friday, April 3, 2009 4:30:09 PM(UTC)
Jeff Buck
Final rinse trickles in, fills in about 1/2 Hr. Then have to turn selector to get it to spin and drain the water
#3 Posted : Friday, April 3, 2009 4:51:21 PM(UTC)
Replacement parts for GE WBSE3120B2WW | AppliancePartsPros.com
It is a GE so getting tech info on line is difficult.
Final rinse is usually just cold water so it could be that there is a problem with it.
Remove the hose from the tap and run it into a pail to check the flow.
Some new homes have hose burst protection and they can cause problems.
Reconnect the hose to the tap and disconnect it from the machine.
Run it into a pail to check the flow. Some hoses have a screen filter built into the sealing washers, also they can collapse internally.
Check the screen filter on the input side of the machine's water valve.
It will have a screen filter.
If dirty clean it.
Do not remove it as it is there to prevent crud from getting into the valve, holding it open and causing a flood.
Jeff Buck
#4 Posted : Friday, April 3, 2009 5:53:56 PM(UTC)
Jeff Buck
I cleaned my screens and my washer is working fine!!! Thanks again
#5 Posted : Saturday, April 4, 2009 5:16:04 AM(UTC)
You may want to drain some water out of your hor water tank.
Use the drain or the pressure relief.
Let it run till the water is clear.
Reduces crud in the water and also makes the tank more efficient.
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
GE Washer Topload model I have a GE top load washer GTW750CPL0DG. It fills and it is running but whe (Washer Repair)
by MimiReel 1/28/2024 12:03:27 PM(UTC)
GE washer GTW750CPL0DG (Washer Repair)
by Guest 1/28/2024 11:49:12 AM(UTC)
GE Washer with bad transmission? (Washer Repair)
by fljlee3 1/16/2024 10:50:07 AM(UTC)
GE washer and dryer lost face clothes (Washer Repair)
by chris24681012 12/19/2023 5:44:47 AM(UTC)
GE washer drain problem (Washer Repair)
by gurka75 11/16/2023 10:07:53 AM(UTC)
GE washer model GTWN4250D0WS fill water but will not agitate or spin during wash cycle (Washer Repair)
by Dweynand 8/29/2023 7:01:15 PM(UTC)
GE Washer model GFAN1000L2WW. Stucked during the washing process with no agitation. (Washer Repair)
by Guest 8/24/2023 4:22:18 PM(UTC)
GE Washer GLWN5550D0WW trying to test if the shifter disengage from the wash basket (Washer Repair)
by steveh1776 3/27/2023 6:00:43 AM(UTC)
GE washer will spin but will not agitate on the wash cycle (Washer Repair)
by Jodibrewer2002@yahoo.com 2/14/2023 10:39:58 AM(UTC)
GE WASHER MAKES GOD AWFUL SOUND AFTER FILLING WITH WATER (Washer Repair)
by Guest 2/12/2023 5:04:03 PM(UTC)
GE Washer GTW335ASN1WW (Washer Repair)
by jmulc82189 2/8/2023 10:36:12 AM(UTC)
GE Washer Ending Cycle after abt 3-5 mins (Washer Repair)
by FelixSS 2/6/2023 5:37:03 PM(UTC)
GE washer wbse4220aoww (Washer Repair)
by Guest 9/21/2022 2:04:51 PM(UTC)
GE washer- washes clothes, spins, drains then fills w water again (Washer Repair)
by Skep19 9/19/2022 9:36:54 AM(UTC)
