puppal
#1 Posted : Monday, July 30, 2012 9:01:04 PM(UTC)
puppal
I have this kitchenaid gas range model KGRS 807 SSS00 and the oven stopped working. We called in a repair man and he said the electronic contorl needs replacing. I just replaced the part number 9762794. when turning on the oven it will very slowly heat up to about 240 after 30-40 minutes. When i look inside the oven I see a electronic element that is red hot located at the top indside the oven. I assume that there is a gas portion that is not working and thats why it taking so long to heat up and not going past 240. Can someone please direct me in what could be wrong with this stove.
Thanks Paul
#2 Posted : Tuesday, July 31, 2012 3:25:55 PM(UTC)
Hi Paul,
Quote:
...When i look inside the oven I see a electronic element that is red hot located at the top indside the oven...
The information you posted is confusing because by the model number you provided this oven has Direct Spark ignition instead of regular glow bar igniters. That means you have to hear a clicking sound when the oven ignites.
Can you provide more detailed description on the problem please?
Here are the breakdown diagrams and Replacement parts for Whirlpool KGRS807SSS00 30" Freestanding GAS OVEN CONVECTION | AppliancePartsPros.com
puppal
#3 Posted : Tuesday, July 31, 2012 5:03:49 PM(UTC)
puppal
Thanks for your quick response. I don't know too much about this stove but that model number is correct and it basically doesn't heat up past 240 degrees and it takes about 30-40 min. However when I do try to use the broil feature I hear a clicking noise twice but it still doesn't heat up.
#4 Posted : Wednesday, August 1, 2012 2:49:49 PM(UTC)
You have to have a simple multimeter to perform a few tests. Let me know when you will be ready.
linmyers
#5 Posted : Tuesday, March 12, 2013 12:18:21 PM(UTC)
linmyers
I have the same issue. My kitchenaid KGRS807SSS00 stove works fine, but the oven wont heat past 200 and that is after 30 minutes or more. I don't see flames when it is set to broil, but the heating element at the top does get red.
I have a simple multimeter. Can you please help me diagnose my issue?
#6 Posted : Tuesday, March 12, 2013 2:15:46 PM(UTC)
Hello,
Can you describe more detailed how the oven Bake and Broil work please?
How does it reignite in both modes?
How long the flame stays on?
Here are the breakdown diagrams and Parts for Whirlpool KGRS807SSS00 Range - AppliancePartsPros.com
linmyers
#7 Posted : Tuesday, March 12, 2013 3:22:24 PM(UTC)
linmyers
There is a knob for bake and broil for the regular oven and a separate one for convection. The flame never comes on. I hear 2 loud clicks when I turn the oven on in any mode, but I don't hear the gas. Also, the self-clean mde does not work. The oven does not get hot at all.
Thank you for your quick reply.
#8 Posted : Tuesday, March 12, 2013 3:28:01 PM(UTC)
You have to start the troubleshooting from testing the gas valve (#13 at the diagram). You can find more information together with the instructions in one of our previous threads: http://forum.appliancepartspros...l-oven-wont-heat-up.html
- The gas valve Part number: 9763716
Kitchenaid KSRG25FKSS15 Refridg buzz/rattle on compressor start (Refrigerator & Freezer Repair)
by Guest 6/23/2024 8:35:15 AM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Kitchenaid KDTE254ESS1 Heater Element (Dishwasher Repair)
by charlie9876 5/28/2024 8:18:41 AM(UTC)
KitchenAid KSC25INSS01 (Refrigerator & Freezer Repair)
by KKellyNC 5/23/2024 4:25:25 AM(UTC)
Kitchenaid Oven range Superba kgsc308lss0 not heating up (Oven Repair (including Ranges and Cooktops))
by rattty 5/19/2024 6:51:16 PM(UTC)
Kitchenaid KDTM604KPS0 (Dishwasher Repair)
by Guest 5/12/2024 5:24:44 AM(UTC)
KitchenAid freezer gasket needed (Refrigerator & Freezer Repair)
by Kris Ballew 4/30/2024 6:27:57 PM(UTC)
KitchenAid freezer door stuck (Refrigerator & Freezer Repair)
by willeaton 4/18/2024 7:31:34 AM(UTC)
KitchenAid KSC25INSS01 issues (Refrigerator & Freezer Repair)
by KKellyNC 4/16/2024 7:28:06 PM(UTC)
Kitchenaid KSSC48QMS02 (Refrigerator & Freezer Repair)
by VinRenzi 4/2/2024 6:26:11 AM(UTC)
Kitchenaid Refrigerator Ice chute frosting up and clogging (Refrigerator & Freezer Repair)
by Guest 3/26/2024 9:05:12 AM(UTC)
Built-In Kitchenaid Mdel KSSC42QMS00 Refrigerator (Refrigerator & Freezer Repair)
by Guest 3/25/2024 6:29:18 AM(UTC)
KitchenAid KSSP42QTS00 Ice dispenser leaking (Refrigerator & Freezer Repair)
by sternern 3/20/2024 2:21:47 PM(UTC)
Kitchenaid ktdm354dss3 doesn’t close completely at the top (Dishwasher Repair)
by Guest 2/29/2024 12:36:40 PM(UTC)
KitchenAid Gar Range - Oven Intermittent Lighting (Oven Repair (including Ranges and Cooktops))
by JDinKTX 2/25/2024 5:05:21 AM(UTC)
