tomlicnk
#1 Posted : 16 years ago
tomlicnk
Views messages in topic : 2
I have unbolted the motor casing from the pump and have removed the pump but can't get the motor out. The motor part number is 675748A. Here is a link to the picture of the motor and pump assembly: WHIRLPOOL Dishwasher pump and motor assembly.
My question is: Do you pull the motor through the inside with the gasket? I can't seem to get it through. Is the gasket supposed to release somehow?
Please help if you have any ideas.
#2 Posted : 16 years ago
You have to unlock the three locking tabs on the bottom of the pump, unscrew the check valve from the pump and push the whole pump & motor assembly up from the under the dishwasher inside.
tomlicnk
#3 Posted : 16 years ago
tomlicnk
Thanks for the reply. Do the 3 locking tabs on the bottom of the pump hold the assembly to the diswasher? Should the seal be tight? Mine isn't budging at all. Where do I find the locking tabs?
#4 Posted : 16 years ago
The locking tabs are shown on the diagram as #26. They are holding the pump to the tub. You have to turn them in order to unlock. You have to push the pump & motor assembly up very hard because the pump seal, aka a motor gasket (#16), is stuck to the tub.
