yucaipahunter
#1 Posted : Monday, March 30, 2009 5:50:57 PM(UTC)
yucaipahunter
My timer will advance in timed setting but not during auto sense dry, I have heat. I replaced the thermal fuse not long ago. I replaced the cycling thermostat ( it was good) the hi temp has continuity, exhaust duct free and clear, dryer heat cycles on and off pretty frequently, temp at exhaust was about 140+- How can I test my timer to be sure ? I followed some tests in my wiring diagram with my meter and most "zeroed" out however on the Auto hi temp setting I measured some resistance, (between TM-WB) not normal right?I just want to make sure before I buy a new timer. Any help would be great.
yucaipahunter
#2 Posted : Monday, March 30, 2009 6:16:26 PM(UTC)
yucaipahunter
I mentioned earlier the heat cycles frequently, what is the average run time for a heat cycle ? My flame seems to only blow for about 20-30 seconds then start up in a bit and do the same ,on /off on /off is this normal ? Thanks
yucaipahunter
#3 Posted : Tuesday, March 31, 2009 2:44:12 PM(UTC)
yucaipahunter
OK no help yet but, to update I replaced the gas valve coils thinking I wasn't getting enough heat, made no difference. I also used an infrared thermometer at the exhaust and my temp is about 125-130 it varies. The heater still cycles pretty frequently and the timer still will not advance in auto setting. I have replaced: thermal fuse, cycling thermostat, gas valve coils, tested the hi limit and by passed it thinking it might be weak, no difference. Any suggestions ? Is it the timer ? What else can I check ? Thanks
yucaipahunter
#4 Posted : Thursday, April 2, 2009 7:11:37 PM(UTC)
yucaipahunter
Opinions, Advice, Help, anyone, Gene ? Thanks. Anyone else have this problem ?
