ajc54
#1 Posted : Tuesday, July 24, 2012 6:13:20 AM(UTC)
ajc54
My ice maker is leaking excess water at the above the front and rear of the icemaker water fill tray. I replaced inlet valve recently and adjusted the fill level with neither having an affect on the issue. The water now appears dirty and after reading similar blogs I am thinking clogged water line or filter. Is there a filter for the water going to ice maker, where is it, should I change it or just clean, what else can I check? Thank You
Simon / APP Team
#2 Posted : Tuesday, July 24, 2012 10:17:00 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The water filter is located in the fresh food top left
Part number: UKF8001
Most likely you need to replace the icemaker
Part number: D7824706Q
Here are the breakdown diagrams and Replacement parts for Maytag MSD2655HES REF - SXS/I&W | AppliancePartsPros.com
Thank you. Post the results.
Simon.
ajc54
#3 Posted : Wednesday, July 25, 2012 4:16:40 PM(UTC)
ajc54
Yes, i know the water filter but I was wondering if there is a second filter for the water to the ice maker?
Why do you think the ice maker needs to be replaced?
Simon / APP Team
#4 Posted : Wednesday, July 25, 2012 5:21:37 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
There is no additional icemaker filter in the domestic refrigerators.
After you replaced the water valve there nothing ells to control the water fill level but the icemaker.
Simon.
ajc54
#5 Posted : Wednesday, August 1, 2012 8:05:31 AM(UTC)
ajc54
Replacing the ice maker corrected the problem. Thanks
Simon / APP Team
#6 Posted : Wednesday, August 1, 2012 9:39:43 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
Guest (5)
