AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
dryer won't turn on, also light stays on with door closed
Dryer won't turn on, also, replace burned bulb, and it stays on with door closed, could this be a bad door switch, or is it mare likely a bad timer?
THIS FORUM IS DEAD!!!!!!! |
Dryer Repair
