juliano
#1 Posted : Wednesday, April 1, 2009 3:18:52 PM(UTC)
juliano
Fridge and frizzer are not cooling. The contol panel number are going up and down.we had a tech looking at it he sayed is the main control board but plus labour and replacing both panels is abouth $500 . You think that coud be the problem and if it is what is the part that we need and where is located .thank you. model number kscs25inss00 kitchen aid
#2 Posted : Thursday, April 2, 2009 2:10:38 AM(UTC)
Here is the parts breakdown
Replacement parts for WHIRLPOOL KSCS25INSS00 | AppliancePartsPros.com
Here is a tech sheet
https://www.servicematters.com/d...0Sheet%20-%202223419.pdf
Not sure what he is talking about re: both panels
Perhaps he wants to replace the control board Item 19 in the "Unit parts" section and the display control board Item 6 in the "Control parts" section.
These could cause the problem.
More info on the problem might help.
When you say not cooling, are both the freezer and fresh food sections at room temperature?
Is the compressor running?
Are condenser coils under the unit clean?
Are the condenser fan and evaporator fans running?
Have you removed the evaporator coil cover, to see if there is any frost at all on the coils?
Have you unplugged it for half an hour or so to see if it will reset?
Could not find a service manual for this unit.
Run the diagnostics on the tech sheet.
Here is a good site with basic fridge info
http://www.applianceaid.com/refrigerator.html
juliano
#3 Posted : Thursday, April 2, 2009 11:35:20 AM(UTC)
juliano
im still confused.the piced that i see there is a little different of the one i see here i wonder if it will work any ways
#4 Posted : Thursday, April 2, 2009 5:53:14 PM(UTC)
Sorry without being there I cannot comment.
juliano
#5 Posted : Monday, April 6, 2009 7:46:21 AM(UTC)
juliano
:confused: can i send you an email of the part of the refrigirator to show you that the part the i got doesnt look the same please anwer me . thank you ......veronica....:(
woodchuckie
#6 Posted : Monday, April 6, 2009 8:04:30 AM(UTC)
woodchuckie
You can post it here by using the manage attachments button in the additional options section below your message when you post a new message.
juliano
#7 Posted : Tuesday, April 7, 2009 4:39:57 AM(UTC)
juliano
i called couple stores and all gidme the same part number as the one i got but i wonder if the part number is just a name to call electric control i called the manufacture kitchenaid they transfer me to sears because they had the pieces for my kind of fridge and they gidme the same part number even that i didnt bought it over ther i order it at appliancespros.
At this point im just going to wait for your anwer because tere is no tech people that i can talk over the phone with you are my last hope:o .Thank you. here are the pictures of my refrigirator and the piece that i just got are this the same???????
juliano attached the following image(s):
#8 Posted : Tuesday, April 7, 2009 2:26:18 PM(UTC)
Looks to me as if you have a main refrigerator control board and the compressor's inverter board.
The control board is in another case, I think!!!
You will see the large wiring harness going into it.
Look in the parts breakdown Item i9 in the "Unit parts" section
unaicker
#9 Posted : Saturday, April 17, 2010 7:13:07 PM(UTC)
unaicker
I just replaced the controller board to fix a similar problem. The board that you have bought is the correct board. The circuit board that you have opened in your refrigerator is the invertor board (i think it controls the compressor). The control board board is to the left of the invertor board - it is covered by a metal enclosure.
