Groups: APP Team
Hi.
Did you check the hi-limit thermostat? Put the temporary jumper wire on it and test run the dryer. If it works - then either the hi-limit or air restriction.
Simon.
Originally Posted by: bcdunmore  Gene Replaced coils and flame goes out in less that one minute I had the same problem, I opened up the front of the dryer and took an air compressor and vacuum and cleaned out everything really well (especially where the gas comes out) and it seemed to have fixed the issue. Give it a try and see if it helps...
