HUWIZARD
#1 Posted : Tuesday, July 17, 2012 5:11:10 AM(UTC)
HUWIZARD
Need help solving a problem. The refrigerator was not cooling and then the flapper for the ice maker start flapping. Then the whole thing just turned off. I hire a Tech and he came out yesterday and replaced the circuit board but he could not reset it in front panel. He charged me alot of money for the circuit board and said sorry just throw the ref away, come on it cost me alot just to do that and he left. I went to ask.com and found the sequence to reset it and the code i needed and it worked but the compressor won't kick in. I have power inside and the fan blowing but no cold air. Could it be the start device or another circuit board?
Simon / APP Team
#2 Posted : Tuesday, July 17, 2012 9:42:51 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check if there is 120VAC to the start relay/overload at the compressor.
No voltage - bad control board.
If there is 120VAC, check the continuity of the compressor's 3 pins.
If you have continuity - replace the starting components.
Here are the breakdown diagrams and Replacement parts for Amana AFI2538AES REF - BOTTOM MOUNTS | AppliancePartsPros.com
Thank you. Post the results.
Simon.
HUWIZARD
#3 Posted : Monday, July 23, 2012 1:21:36 PM(UTC)
HUWIZARD
the technician at ASK.COM gave me the wrong code to reset it. I check the model number again the darn code was right below it and it reset itself. Thats the info anyway.
Simon / APP Team
#4 Posted : Monday, July 23, 2012 1:52:49 PM(UTC)
Simon / APP Team
Groups: APP Team
Thank you for the input.
Simon.
Amana Refrigerator Handle (Refrigerator & Freezer Repair)
by Guest 3/24/2021 10:53:43 AM(UTC)
Amana Refrigerator Thermostat? (Refrigerator & Freezer Repair)
by yaworski 3/24/2021 10:42:55 AM(UTC)
Amana Refrigerator, only lights work (Refrigerator & Freezer Repair)
by thafemann 9/12/2020 4:40:51 PM(UTC)
Amana refrigerator - leak in back? Should I worry? (Refrigerator & Freezer Repair)
by beb123 8/11/2019 9:20:14 AM(UTC)
Amana Refrigerator TR25VW Leaking From Freezer (Refrigerator & Freezer Repair)
by Lamf77 11/29/2017 7:00:13 AM(UTC)
Amana Refrigerator (Refrigerator & Freezer Repair)
by pasjr 10/18/2017 8:42:26 PM(UTC)
Amana refrigerator starts, clicks and stops (Refrigerator & Freezer Repair)
by carmeljacques 9/25/2016 8:23:31 AM(UTC)
Amana Refrigerator - Will Not Start (Refrigerator & Freezer Repair)
by CCICH 8/12/2015 10:34:17 AM(UTC)
Amana Refrigerator/Freezer Not Cooling or Freezing (Refrigerator & Freezer Repair)
by willie1280 5/27/2015 10:24:46 AM(UTC)
Amana refrigerator will not start (Refrigerator & Freezer Repair)
by jasonliang80 10/5/2013 10:12:33 AM(UTC)
Amana Refrigerator and Freezer not cooling (Refrigerator & Freezer Repair)
by gabyrink 3/17/2013 5:10:31 PM(UTC)
Amana refrigerator not cooling (Refrigerator & Freezer Repair)
by bruihl 3/5/2013 5:22:05 PM(UTC)
Amana refrigerator freezing (Refrigerator & Freezer Repair)
by scottor 10/12/2012 12:40:32 PM(UTC)
Amana refrigerator not working but bottom mounted freezer working (Refrigerator & Freezer Repair)
by topperdude 7/10/2012 8:30:30 AM(UTC)
Amana Refrigerator/Freezer Problem (Refrigerator & Freezer Repair)
by t189dms 6/13/2012 7:39:08 AM(UTC)
