My Whirlpool gas dryer won't start. I have power to the unit. The timer runs, no tumbling, no heat when I press the start button. I can hear the relay click when I press the button after turning the dial to off, then to a setting. Tried all settings. Nothing works. There is continuity across the the thermal fuse.
Any help would be appreciated.
I saw a post with a similar problem, but on a Whirlpool electric dryer. That individual finally determined that the issue was the timer motor. How would one go about testing that device?
Groups: APP Team
Hi. Using the multimeter check the continuity: - door switch Blue to White closed. - start switch Black to Blue closed (with power on and switch pushed in). - timer on timed regular TM-OR, BK-BU, T-W all closed. If all of the above checks OK - replace the motor. Here are the breakdown diagrams and Replacement parts for Whirlpool LGR7648PQ0 29" GAS DRYER | AppliancePartsPros.comThank you. Post the results. Simon.
- door switch Blue to White closed. Disconnected door switch and tested outer leads with door closed, then open: OK
- start switch Black to Blue closed (with power on and switch pushed in). Disconnected wires from timer motor and tested Black to Blue: OK
- timer on timed regular TM-OR, BK-BU, T-W all closed. With dryer unplugged, set timer to "timed drying" and tested prongs of timer motor. TM-OR: OK BK-BU: OK T-W: NO continuity Does this indicate a different problem? Thanks in advance for all of the assistance
Groups: APP Team
Hi.
Install the jumper on T-W and start the dryer. If it kicks on - replace the timer.
Simon.
That was it! Thanks so much for the assistance. You're an asset to the forum. Parts will be on order tonight.
Groups: APP Team
Simon. Can you run the dryer with the jumper on T-W, without replacing the timer? Thanks Greg
Groups: APP Team
Hi.
Why wouldn't the manufacturer make the timer with contacts T-W closed all the time? If the timer is shut, replace it.
Simon.
