jeffmaaske
#1 Posted : Tuesday, July 17, 2012 8:38:23 PM(UTC)
jeffmaaske
My Whirlpool gas dryer won't start. I have power to the unit. The timer runs, no tumbling, no heat when I press the start button. I can hear the relay click when I press the button after turning the dial to off, then to a setting. Tried all settings. Nothing works. There is continuity across the the thermal fuse.
Any help would be appreciated.
jeffmaaske
#2 Posted : Thursday, July 19, 2012 3:37:52 AM(UTC)
jeffmaaske
I saw a post with a similar problem, but on a Whirlpool electric dryer. That individual finally determined that the issue was the timer motor. How would one go about testing that device?
Simon / APP Team
#3 Posted : Thursday, July 19, 2012 2:26:22 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Using the multimeter check the continuity:
- door switch Blue to White closed.
- start switch Black to Blue closed (with power on and switch pushed in).
- timer on timed regular TM-OR, BK-BU, T-W all closed.
If all of the above checks OK - replace the motor.
Here are the breakdown diagrams and Replacement parts for Whirlpool LGR7648PQ0 29" GAS DRYER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
jeffmaaske
#4 Posted : Thursday, July 19, 2012 3:50:19 PM(UTC)
jeffmaaske
Disconnected door switch and tested outer leads with door closed, then open: OK
Disconnected wires from timer motor and tested Black to Blue: OK
With dryer unplugged, set timer to "timed drying" and tested prongs of timer motor.
TM-OR: OK
BK-BU: OK
T-W: NO continuity
Does this indicate a different problem?
Thanks in advance for all of the assistance
Simon / APP Team
#5 Posted : Thursday, July 19, 2012 4:20:05 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Install the jumper on T-W and start the dryer. If it kicks on - replace the timer.
Simon.
jeffmaaske
#6 Posted : Thursday, July 19, 2012 4:39:38 PM(UTC)
jeffmaaske
That was it!
Thanks so much for the assistance. You're an asset to the forum.
Parts will be on order tonight.
Simon / APP Team
#7 Posted : Friday, July 20, 2012 8:05:13 AM(UTC)
Simon / APP Team
Groups: APP Team
My pleasure.
Simon.
geberl
#8 Posted: : Wednesday, August 22, 2012 7:14:23 PM(UTC)
geberl
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Simon.
Can you run the dryer with the jumper on T-W, without replacing the timer?
Greg
Simon / APP Team
#9 Posted : Thursday, August 23, 2012 8:38:18 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Why wouldn't the manufacturer make the timer with contacts T-W closed all the time?
If the timer is shut, replace it.
Simon.
