2 Pages<12
Simon / APP Team
#11 Posted : Thursday, July 12, 2012 4:48:50 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The power supply board is located on the right side bottom behind side panel. Sorry for the pure engineering.
Thank you.
Simon.
Steve Carlini
#12 Posted : Thursday, July 12, 2012 5:03:03 PM(UTC)
Steve Carlini
Thanks So I have to fully remove the oven from cavity to remove side panel to access the power supply module? I did not see that in the refernce diagrams? Steve
Simon / APP Team
#13 Posted : Thursday, July 12, 2012 5:08:21 PM(UTC)
Simon / APP Team
Groups: APP Team
You will have to trust me on this one.
Simon.
Steve Carlini
#14 Posted : Friday, July 13, 2012 10:37:16 AM(UTC)
Steve Carlini
Simon
Hi I checked the voltages as you recommended and I have 120V between P1 to P6, I turned on the oven and measured 120V between P1-1 and P2 and P1-1 and P8. The relay board seems to be working. Do you have any additional suggestions for me to troubleshoot much appreciated. Steve
Steve Carlini
#15 Posted : Friday, July 13, 2012 12:00:27 PM(UTC)
Steve Carlini
Simon
Hi I want to thank you so much for the help I did additional troubleshooting using the wiring info you gave me and determine a loose connection downstream of power board. Now oven broiler etc is up and running. appreciate the support and if I need appliance support I know the compnay to use. regards Steve
Simon / APP Team
#16 Posted : Friday, July 13, 2012 12:10:03 PM(UTC)
Simon / APP Team
Groups: APP Team
You are very welcome.
Simon.
2 Pages<12
