norman13fo
#1 Posted : Thursday, July 12, 2012 5:15:29 AM(UTC)
norman13fo
The clean light is flashing (7 blinks per cycle). The owners manual suggests checking the heater circuit. How do I do this?
#2 Posted : Thursday, July 12, 2012 2:53:29 PM(UTC)
You have to have a simple multimeter. Let us know when you will be ready.
norman13fo
#3 Posted : Thursday, July 12, 2012 4:09:08 PM(UTC)
norman13fo
Thanks, I do have a multimeter. Now what?
#4 Posted : Friday, July 13, 2012 10:16:16 PM(UTC)
The heating circuit consists of three parts. They are: the heating element, the hi-limit thermostat (located under the tub on the left side) and the thermistor (located on the right side of the pump sump from under the dishwasher ).
All three parts can be checked for continuity. The normal readings are: the heating element - between 10-30 Ohms, the hi-limit the thermostat - close to 0 Ohms and the thermistor - between 48-52K Ohms @ 77°F.
If all of these parts are good, replace the control board.
- The heating element Part number: W10134009
- The hi-limit thermostat Part number: 661566
Part number: 661566
- The thermistor Part number: 8269208
- The control board Part number: 8564547
norman13fo
#5 Posted : Saturday, July 14, 2012 12:21:56 AM(UTC)
norman13fo
Thank you. This is exactly what I needed to know.
