2 Pages12>
doanhtran@gmail.com
#1 Posted : Monday, July 9, 2012 7:50:20 PM(UTC)
doanhtran@gmail.com
I could use some suggestions on this dishwasher..
It was not draining so I took out the hose and sump and check ball.. it was coated with grease and hardened cornbread powder?
I even turn the impeller and it does not appear to be stuck at all. I put everything back and ran the dishwasher..
it still would not drain!
I am curious to know how to check the check valve for this unit.. It is integraged with Manufacturer Number 8520839..
thanks in advance
#2 Posted : Tuesday, July 10, 2012 7:33:58 PM(UTC)
Does it wash?
Did you clean the ball?
doanhtran@gmail.com
#3 Posted : Tuesday, July 10, 2012 7:52:21 PM(UTC)
doanhtran@gmail.com
washes fine.. just does not drain..
I cleaned the ball and the sump area.. How do I determine if the check valve is good or bad?
I may have to take the pump assembly out to check (I hope not).. is there a trick to removing the sprayer assembly?
thanks in advance
#4 Posted : Tuesday, July 10, 2012 8:45:35 PM(UTC)
How much water is left inside the dishwasher?
Where the drain hose is connected to? Do you have an air gap installed on top of the sink?
doanhtran@gmail.com
#5 Posted : Tuesday, July 10, 2012 8:50:54 PM(UTC)
doanhtran@gmail.com
a lot of water.. 1 to 1.5 inch..
the drain hose is connected directly to the garbage disposal.. no air gap installed on top of sink.
thanks again
#6 Posted : Tuesday, July 10, 2012 9:00:01 PM(UTC)
Disconnect the drain hose from the garbage disposal and put it in a large bucket. Check how it will drain.
P.S. Did you replace the garbage disposal recently?
doanhtran@gmail.com
#7 Posted : Tuesday, July 10, 2012 9:18:17 PM(UTC)
doanhtran@gmail.com
No the garbage disposal is old..
I will put the hose in the bucket and check.. Since I am out of town for a few days..
just curious..
if there was no flow, what should I check next?
else what if there was very little flow?
#8 Posted : Thursday, July 12, 2012 1:09:26 PM(UTC)
One more thing you may want to check: does the motor run when the control calls for drain?
doanhtran@gmail.com
#9 Posted : Thursday, July 12, 2012 1:29:14 PM(UTC)
doanhtran@gmail.com
stupid question here but how do I activate the drain function?
this dishwasher only has the rotary knob and drain function is not on it..
#10 Posted : Thursday, July 12, 2012 1:46:07 PM(UTC)
The motor in this dishwasher is reversible what means it turns in opposite direction for drain. Slowly turn the knob. The motor should stop for a few seconds and switch from wash to drain.
Whirlpool dishwasher wont drain (Dishwasher Repair)
by JayTeeC 3/30/2014 1:53:15 PM(UTC)
Whirlpool Dishwasher wont drain water (Dishwasher Repair)
by shirump 5/30/2010 8:38:25 AM(UTC)
2 Pages12>
