2 Pages<12
sc00bie
#11 Posted : Wednesday, October 17, 2012 10:09:00 PM(UTC)
sc00bie
Did you figure out the problem? I have the same problem(same model Whirlpool DU811SWKU0). It leaves about 1 to 1.5 inches of water. I hear the motor turn. I took it apart, made sure check valve, ball, etc was clean. Even took out the drain pipes, gap and made sure it was clear. What could be wrong?
Thanks in advance!
doanhtran@gmail.com
#12 Posted : Thursday, October 18, 2012 8:43:32 AM(UTC)
doanhtran@gmail.com
yes.. mine was a clogged drain line.. it was completely clogged with stuff.. thus the pump could not push the water thru. take your drain line out side and use a garden hose to make sure it is not clogged.
hopes this helps
Guest (4)
Whirlpool dishwasher wont drain (Dishwasher Repair)
by JayTeeC 3/30/2014 1:53:15 PM(UTC)
Whirlpool Dishwasher wont drain water (Dishwasher Repair)
by shirump 5/30/2010 8:38:25 AM(UTC)
2 Pages<12
