2 Pages<12
#11 Posted : Thursday, June 14, 2012 10:20:17 AM(UTC)
Gary,
No water can be expected from the water dispenser after you swapped the wires.
izzy416
#12 Posted : Sunday, July 8, 2012 8:03:20 PM(UTC)
izzy416
Help! I took the advice of Gene. I replaced the dual water input valve. I still have the same problem. Ice maker is not making ice. Water dispenser works fine when filter is not in place and using the bypass cap instead. Once I attach the filter, the water stops coming out of the dispenser and a loud clicking sound comes from the refrigerator. (Seems to be coming from the back wall of the refrigerator near the filter input) This is the second filter I have had on in less than a year and this happens.
All of this was happening the same way before I replaced the dual input valve.
#13 Posted : Monday, July 9, 2012 5:39:05 PM(UTC)
You may want to replace the water filter housing. It has a check valve inside which can cause such problem.
- The water filter housing Part number: 67006524
ice maker/water dispenser (Refrigerator & Freezer Repair)
by minniepin 6/19/2008 12:17:27 PM(UTC)
2 Pages<12
