patrickemb
#1 Posted : Monday, July 9, 2012 11:51:15 AM(UTC)
patrickemb
I have trouble codes F3 E0 showing. I have pulled both sensors and checked them with a ohm meter. they both tested 1136 and 1134. Are they both bad? What are the chances both have gone out? Read on-line that they need to be between 1000 and 1100 ohms to be working properly. Need a little more advice from someone please. They were tested at room temp.
Simon / APP Team
#2 Posted : Monday, July 9, 2012 1:13:23 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The F3 E0 code means that the upper oven sensor is bad.
Your test not proving this. Run the test again but this time check the resistance at the control board, because it may be a bad wire harness or the plug.
If you still getting the same reading - then your control board is bad.
Here aret he breakdown diagrams and Replacement parts for Whirlpool KEBS207DBL6 BUILT - IN ELECTRIC OVEN | AppliancePartsPros.com
Thank you. Post the results.
Simon.
patrickemb
#3 Posted : Monday, July 9, 2012 1:15:15 PM(UTC)
patrickemb
Ok, thanks I'll check that out and get back with you.
Simon / APP Team
#4 Posted : Monday, July 9, 2012 2:57:19 PM(UTC)
Simon / APP Team
Groups: APP Team
Thanks. Keep us posted.
Simon.
patrickemb
#5 Posted : Tuesday, July 10, 2012 11:03:03 AM(UTC)
patrickemb
I checked at the control board. It ohmed out OK. Guess I'll replace the board. Called to check price of the board and they are discontinued. Found a refurb on-line. Can't figured out why they were discontinued the oven is not that old.
oven temp sensors interchangeable? (Oven Repair (including Ranges and Cooktops))
by dumbcarpenter 1/18/2010 5:49:18 PM(UTC)
