I have trouble codes F3 E0 showing. I have pulled both sensors and checked them with a ohm meter. they both tested 1136 and 1134. Are they both bad? What are the chances both have gone out? Read on-line that they need to be between 1000 and 1100 ohms to be working properly. Need a little more advice from someone please. They were tested at room temp.
Groups: APP Team
Ok, thanks I'll check that out and get back with you.
Groups: APP Team
Thanks. Keep us posted.
Simon.
I checked at the control board. It ohmed out OK. Guess I'll replace the board. Called to check price of the board and they are discontinued. Found a refurb on-line. Can't figured out why they were discontinued the oven is not that old.
