hi i have just finish opening the area in the freezer that knob in item #2 in the cabinet diagram which should regulate the air flow makes no sense it is not connected to anything behind it it just rotates and make clicking sounds. There should be a damper attached to it which opens and closes the air path, see Item 4
so tell me is it the fan item #13 thanks Yes it looks like the fan is shot. You could check it for continuity with a meter. You could also check the plug to be sure it is getting voltage. Or just order the fan, it is not uncommon for them to go. You may also want to order Item 4, the damper. Check to see if it has fallen off and laying at the bottom of the freezer. Weird that it is not there!
THIS FORUM IS DEAD!!!!!!! |
thank again for getting back to me does the fan blake come off from item 13 and how do you take it off
I believe it just pulls straight off.
When you order make sure that you ask if the old blade will fit the new motor. I mention this because they show the blade as F5 at the end of the list and this often means it has been changed for some reason. |
thank you i will order it today and i will ask them about the fan blade. also this damper as you call it item#4 it is there but it is not connected to anything it just backs into the plastic wall so i am confused how could it regulate air flow when is not connected to anything thanks
The knob on the cover plate should turn it. |
i just want to say thank you. i received the fan motor on friday replaced it on saturday and the frige is fine. you have been a great help and the parts were shipped on time without any problem. you are the best thank you. ps what is the recommend setting for the fridge if the max is 6
You are welcome, I am glad it worked out for you.
I would put it at 4 and see how it goes. |
