jbuffkin
#1 Posted : Saturday, July 7, 2012 5:20:20 AM(UTC)
jbuffkin
Our fridge is approx 5 yrs old. Within the past few days when it is running it sounds as though the fan is vibrating.
We've taken the back off & vacummed out all the trash & dust bunnies. But the problem is still there.
It still cools & makes ice just fine. Just loud as &^%$ - wakes me up at night.
#2 Posted : Sunday, July 8, 2012 1:34:59 AM(UTC)
Replacement parts for Whirlpool ED5PHEXRB00 REFRIGERATOR | AppliancePartsPros.com
First you have to find out which fan is making the racket.
If the evaporator/freezer fan (Item 7 in Section 1): check that there is not an ice build up on by the fan blade that is causing the noise. If none, then I would replace the fan.
If the condenser/compressor fan (Item 24 in Section 12): check that the fan blades are clean and not hitting anything. If OK I would replace the fan.
jbuffkin
#3 Posted : Sunday, July 8, 2012 7:18:09 AM(UTC)
jbuffkin
We took the back cover off - it is the fan that is on the right hand side toward rear of fridge.
