2 Pages12>
wmrbwell
#1 Posted : Sunday, December 2, 2007 1:03:00 AM(UTC)
wmrbwell
I have had this washer for about 3 1/2 years, no problems till now.
When I start the wash cycle water fills the bleach dispenser also.
Everything else seems to work fine wash, rinse, spin. I can't use the bleach because of this.
#2 Posted : Sunday, December 2, 2007 9:40:12 PM(UTC)
In order to provide most accurate advice we need the complete model number of the washer.
wmrbwell
#3 Posted : Monday, December 3, 2007 4:32:49 AM(UTC)
wmrbwell
It is MOD MAH6500AWW. I was at work and didn't have that on my first post.
#4 Posted : Monday, December 3, 2007 10:38:37 AM(UTC)
Most likely the problem is a shorted bleach solenoid on the dispenser water valve (#14 on the control panel & top break down diagram) or a shorted control board (#17 on the control panel & top break down diagram).
You can find more specific instructions in the service manual.
- The part number for the dispenser water valve AP3464761
- The part number for the main control board AP3449382
- Here are the break down diagrams for the Maytag Neptune washer Model MAH6500AWW
jjrapp
#5 Posted : Wednesday, July 9, 2008 9:22:12 AM(UTC)
jjrapp
I'm having the same problem, but my Maytag Neptune model number is MAH3000AWW. The parts diagram doesn't seem to show a solenoid for this model. Which part is the most likely culprit and which components must be removed in order to access it? Any suggestions would be greatly appreciated.
#6 Posted : Wednesday, July 9, 2008 12:31:00 PM(UTC)
jjrapp,
Most likely the problem is a bad wax motor in the dispenser. This part does not come separate and you have to replace the whole dispenser assembly.
- The part number for the dispenser assembly is AP252043
Here are the break down diagrams for the Maytag Neptune washer Model MAH3000AWW
jjrapp
#7 Posted : Friday, July 11, 2008 8:33:59 AM(UTC)
jjrapp
Thanks for the quick reply. Now I can't figure out how to access the dispenser assembly. The top cover seems to be held down by the top cover spacers and the corner braces. Perhaps I have to remove the door and the shroud brackets first? Or is there a quick release for the top cover?
#8 Posted : Friday, July 11, 2008 10:20:30 AM(UTC)
You can find the complete instructions in the Service manual.
jjrapp
#9 Posted : Saturday, July 12, 2008 9:40:30 AM(UTC)
jjrapp
The linkage between the wax motors and the rotary nozzle had a fair amount of calcification build-up. After cleaning that area, the dispenser now works just fine. Thanks for the help! :)
#10 Posted : Monday, July 14, 2008 5:25:46 PM(UTC)
We're glad you were able to fix it.
2 Pages12>
