ANDYSUE57
#1 Posted : 16 years ago
ANDYSUE57
How Do I Replace The Defrost Heater In My Frig
woodchuckie
#2 Posted : 16 years ago
woodchuckie
remove the evaporator cover to gain access.The back panel in the freezer. Then remove the the 1/4" screw that holds the evaporator at the bottom and moved the evaporator outward to remove the heater element. Then install new heater element from the bottom of the evaporator making sure it is in the center of the evap coils.
I assume you have tested and found the heater bad.
ANDYSUE57
#3 Posted : 16 years ago
ANDYSUE57
I ASSUME IT IS NO GOOD, IT IS BROKEN INTO 2 PIECES, AND THE PICTURE OF THE REPLACEMENT IS IN ONE PIECE. THANK-YOU FOR YOUR ANSWER, :)
Frigidaire side-by-side - ice at bottom of freezer? (Refrigerator & Freezer Repair)
by stupendousyappi 4 years ago
Frigidaire side-by-side w no control display lights (Refrigerator & Freezer Repair)
by Tlai95 11 years ago
Frigidaire side-by-side fridge side leaking under crisper (Refrigerator & Freezer Repair)
by FixingIt 11 years ago
Repair Directions Needed for Frigidaire side-by-side (Refrigerator & Freezer Repair)
by DV19 13 years ago
Frigidaire side-by-side cooling problems (Refrigerator & Freezer Repair)
by ChrisTN 13 years ago
Frigidaire side-by-side --- no ice, no water (Refrigerator & Freezer Repair)
by kosamson 15 years ago
How do I change the water actuator on Frigidaire Side-by-side (Refrigerator & Freezer Repair)
by Tosha1 16 years ago
