Hi all. I have a Frigidaire FHS2622MSJ side-by-side fridge/freezer that came with my house 7 years ago. I've begun noticing that the bottom of the freezer side, under the slide-out plastic drawer, has a slow but steady layer of ice building up. I tap it and break out the ice every few days. Here are the steps I've tried for troubleshooting: Removed light bulb - thinking maybe it was staying on and melting ice in ice tray? Turned off ice maker - thinking maybe it was leaking when filling with water? Emptied ice maker - thinking maybe ice was melting? None of the above steps changed anything. Right behind the slide-out drawer is a grate (in front of the evaporator?) and I see a lot of ice building up behind and under it. I think that's where the water for the ice is coming from, but I haven't emptied the freezer and taken off the panel in front of it yet. Does anyone have any suggestions? TIA, Brian Edited by user Thursday, July 22, 2021 11:31:54 AM(UTC)
| Reason: Not specified
