2 Pages<12
Simon / APP Team
#11 Posted : Thursday, June 28, 2012 5:18:32 PM(UTC)
Simon / APP Team
Groups: APP Team
This is the defrost thermostat Part number: 5303918214
Did you reed my post on how to initiate the defrost?
Do you mind just do that and if there is no 120VAC going to the heater and all the plugs inside the freezer at the evaporator are OK- PLEASE, replace the control board.
Here are the breakdown diagrams and Replacement parts for Frigidaire FLSC23F6DSN Frigidaire/refrigerator | AppliancePartsPros.com
Simon.
broderp
#12 Posted : Thursday, June 28, 2012 5:24:33 PM(UTC)
broderp
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
To activate manual defrost press and hold freezer t* UP key while pressing fresh food t* DOWN key 5 times within 6sec. To deactivate defrost repeat the steps.
The defrost is an Adaptive Defrost Control not just the timer.
Thank you.
Simon.
I totally missed this. I'll try this after dinner. :p
It was 104 degrees today,with a heat index of 107. I'm beat, :confused: but I need to get this fixed. I've started price shopping for the parts that may be affected.
Thanks Raymond
broderp
#13 Posted : Thursday, June 28, 2012 6:14:43 PM(UTC)
broderp
Simon.
This is ODD. :confused: :confused: I did the sequence mentioned to initiate defrost, the display said "dF". Sounds good do far....
I am also an idiot. :rolleyes: I reached in and pushed up on the Defroster Heater after about 1 minute of starting the defrost cycle.....AND BURNED the crap out of my hand. I have a nice straight burn line across my four fingers where I pressed up on the element. Lets say that it is working. ;) ( I also verified there was 118V to the element.)
So now my quandry, whats going on here? The next logical questions being:
What tells the main board to turn on the element?
How long is the average Defrost Cycle?
I suppose I had a loose connection, I did disconnect everything, poke around the connections and reconnected them up. :confused:
I'm going to check it again later.
Thanks,
Raymond
Simon / APP Team
#14 Posted : Friday, June 29, 2012 9:14:30 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The logistics in the control board failed. Replace the board.
Simon.
broderp
#15 Posted : Friday, June 29, 2012 11:41:56 AM(UTC)
broderp
Hi.
Simon.
Ok, but what tells the board it's time to defrost if it's a ADC system (Auto Defrost Cycle) and not just on a Timer and runs regardless every "X" hours for "X" minutes?
As an engineer, I have to wonder if its feasable (read cheaper) to find an alternate power source and rig a R/C timer circuit to turn on & off the element. :rolleyes:
broderp
#16 Posted : Sunday, July 1, 2012 6:24:06 AM(UTC)
broderp
What role do the two thirmistors have in the defrost cycle? I have two of them as well as a thermostat. (There's also a thermistor in the ice maker, but I have to believe it's dedicated to the ice maker mold heater)
Raymond
2 Pages<12
