My Frigidaire washer will not stop filling of water. I have replaced the switch Pressure for water level. but still the same thing.
Groups: APP Team
Hi. Turn the washer to fill and then unplug it. If the water still coming into the washer - replace the water inlet valve. If it stops - check the air pressure hose for cracks and holes. They call it Chamber Part number: 134369900
Originally Posted by: Chad993 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) My Frigidaire washer will not stop filling of water. I have replaced the switch Pressure for water level. but still the same thing. that hose does not leak air or water.
Groups: APP Team
Hi. If the water stop filling in when you unplug the washer check the wire harness from the pressure switch to control board, check all the connectors at control board. If all checks fine - replace the control board. Control board Part number: 137006000
