TIMMO
#1 Posted : Monday, March 30, 2009 1:38:01 PM(UTC)
TIMMO
I HAVE A QUESTION ABOUT MY ICE-MAKER.THE WATER SUPPLIE IS ON MY REVERSE OSMOSIS SYSTEM,THE CUBES THAT COME OUTARE SMALL AND HOLLOW.THE WATER FROM THE DOOR IS VERY SLOW ALSO.IS THIS PROBLEM FROM LACK OF PROPER PRESSURE TO WATER VALVE AND REFRIG FROM THE REVERSE OSMOSIS SYSTEM,OR A FAULTY WATER VALVE.???.
WE USED THE REVERSE OSMOSIS SUPPLIE WATER,BECAUSE OUR WATER IS TERRIBLE.!!!.I HAVE ALREADY CHANGED THE INSIDE REFRIG FILTER.???:confused:
Drags1998
#2 Posted : Monday, March 30, 2009 2:13:00 PM(UTC)
Drags1998
The ONLY problem is LACK of water, Either from a kinked line or from low pressure, If you can increase the flow, It will start making regular sized cubes again!!! Same crappy water that wrecked your washer???? How did you make out with that?:)
TechnicianBrian
#3 Posted : Monday, March 30, 2009 2:15:29 PM(UTC)
TechnicianBrian
Hollow ice cubes are generally a result of to little water in the mold, usually the result of low water pressure. If the water from the dispenser is also slow, I would suspect low pressure to the valve as the dispenser and the ice maker use different valves. You may want to check the pressure into the valve and see if it is noticeably slow from the R.O. system because if it's not, then you may want to change the valve.
TIMMO
#4 Posted : Monday, March 30, 2009 4:37:54 PM(UTC)
TIMMO
Sears Tech Came-out And Comfirmed My Diagnosis On The Rear Tub/bearing And Inner Basket Worn-out,to The Tune Of 1200.00 In Parts And 288.00 For Them To Repair It.they Will Pay For The Parts,but I Will Have To Eat The Labor.that Sucks,because I Know I Can Do It My Self.!!!! I Just Need The Parts.the Parts Will Be Sent To My House For Me To Check Out For Damage/then Call To Have The Repair,performed By There Techs.i Guess They Have To Do The Repairs,if They Warrantee The Defective Parts.!!!
woodchuckie
#5 Posted : Monday, March 30, 2009 5:49:45 PM(UTC)
woodchuckie
Yea, that makes sense.
Guest (4)
